Geoscan-Edelveis Image
2023-12-20 09:24:59, 09:26:59, 09:28:59 UTC
Data I uploaded to SatNOGS DB
hello, I need help, I receive the frames on sharp sdr but the software does not decode it.
what parameter should we have in soundmodem? Is it possible to have a baseband test to see if my settings are correct.
thank you
Windows software: GitHub - Foxiks/Geoscan-Edelveis-Decoder: Real-time image decoder for Geoscan-Edelveis satellite
sound modem setting
Your SoundModem settings are correct. Check that the Filter Audio is turned off in the SDR#. Also disable all the equalizers.
You can replay the audio of this observation to test your setup:
Hello! You need to transfer audio from SDR# to modem using VB CABLE. Also make sure that the modem is showing data packets.
@EU1SAT Ok for setting, and the filter audio is turn off.
@PE0SAT Thanks i will test
@Foxiks yes everything already goes through vb cable.
Thank you for your response.
I will try with a test file and I will get back to you. ![]()
Ugh just missed the Angola transmission, if it had started just two minutes earlier I would have captured a great signal
I saw the beginning of the transmission but it was too weak…
Geoscan-Edelveis Image 2023-12-21 11:27 UTC received by EA4SG in Madrid, Spain
Received with errors and edited…
What is that circular effect in the right bottom part of the image?
2023-12-21 08:24:59 UTC
2023-12-21 09:55:59, 09:57:59, 09:59:59 UTC
I finally managed to decode with the test file after several attempts. ![]()
In fact I had a problem with one of the VB Cable outputs
by selecting another, it worked immediately. Now we just have to wait for a passage. ![]()
Lens flare
Good afternoon! New schedule for image transmissions from the Geoscan-Edelveis satellite for December 22-24. UTC time!
22.12
Ghana (11:54-11:56-11:58-16:30-16:32)
Chukotka (22:58-23:00)
23.12
Issyk-Kul (06:21-06:23-07:53-07:55-07:57)
Türkiye (09:24-09:26-09:28)
South Africa (10:54:30-10:56:30-10:58:30-12:24-12:26-12:28-16:59-17:01-22:26)
24.12
Khabarovsk (06:52-06:54-06:56-08:21-08:23-08:25-08:27)
Caucasus (08:22-08:24-08:26)
Crete (09:52-09:54-09:56)
Angola (11:23-11:25-11:27)
2023-12-22 10:28:58, 10:29:46 UTC
Received in Portugal 22-12-23 11:55 UTC
2023-12-21 22:30:59
2023-12-22 10:26:58 UTC
Hi all! Here is the new schedule for transmitting images from the Geoscan-Edelveis satellite for 12/26/2023. UTC time!
Yakutia - (04:46-04:48-04:50-05:07-05:08:30)
Everest - (06:19-06:21-06:23-07:49-07:51-07:53)
Crimea - (09:21-09:23-09:25-09:27)
South Africa - (10:50-10:52-10:54)
Mali - (12:20-12:22-12:24-16:56-16:58)
Transmission 26.12 09:21-09:23-09:25
Istanbul, Bosfor, Türkiye
hello Geoscan team , merry christmas to everyone
i have also received telemetry and my first image above belgium .sorry only blue sky and the rounding from the earth …
sdrsharp and ub1qbj decoder and vb cable
antenna non amplified and no yagi antenna used , just a simple omnidirectional ata turnstyle antenna
despite no lna and 25 m coax cable this picture from geoscan edelveis sat on 436 MHz
good luck team , nico de roo on7ndr .
