First, thanks for such a great program! I’ve converted several hams from SatPC32 to GPredict!
Second, I currently show both the Upcoming Passes and List view because I want to see both the “Next Event” and the “AOS/LOS”. I realized that I can show everything I want in the List view except AOS/LOS. If AOS/LOS was available in the List view, I wouldn’t even bother to show the Upcoming Passes view since the information would then be redundant.
My feature request is that you add AOS/LOS (like in the Upcoming Passes view) to the List view. Then the Upcoming Passes view is basically redundant and not needed. This would allow more space in the module layouts.
Yes, exactly! Sometimes I want to know that in 27 minutes something is happening and if it’s more than an hour away I usually just want to know the time like 5:07 pm and I don’t want to keep doing the math back and forth. That’s why I always show the Upcoming Passes view and the List view with “Next Event”.
I’ve attached an example. If you look at the bottom right, you will see I have the List view with the Upcoming Passes view under it. The only reason I display the Upcoming Passes view is for the AOS/LOS countdown. If the AOS/LOS countdown was also available in the List view, I could show twice as many satellites because I would not display the Upcoming Passes view and just make the List view longer.
Hope that helps! Thanks again for a great program!
-David, N9KT
