If that is TBEX-A, on one hand, it’s a strong signal. On the other hand, we should be seeing 500 byte bursts at 10 s intervals. This continuous transmission would be bad.
The sats are scheduled to power cycle tonight or tomorrow depending on the clocks. We may see a change in behavior.
From the latest observations and the latest space-track TLEs:
TBEx-A
one of 44354-44357 (chosen in network: 44354)
TBEx-B
no data (chosen in network: 44354)
ARMADILLO
no data (chosen in network: 44347)
PSat-2
no data in UHF from amsat list it transmits only SSTV when in Sun, now in southern hemisphere, some data in VHF not enough for TLE assignment, VHF is now closed until further notice (chosen in network from tweeter: 44348)
BRICSat-2
no data in UHF, from data in VHF one of 44354-44357 (chosen in network: 44356)
We had one good PSat-2 observation so TLE should be one of 44354-44357 (chosen in network: 44357)
For the successful PSat-2 observation the signal is ~10KHz off. Not sure if it was the station or the satellite, we will need to wait for more observation to be sure.
PSat-2 UHF Transmitters seems to be 4.4KHz off, I have added this change in db and updated scheduled observations. 44348 still seems to be the right object to follow for TLEs for PSat-2
44348, 44352, 44354-44357 (changed to 44355 in network)
PSAT-2:
44354 or 44355 (changed to 44354 in network)
BRICSAT-2:
from this observation the only one that probably have its signal in UHF 44354 or 44355 (changed to follow 44355 in network)
CP9 (LEO)
44360 or 44361 (changed to 44361 in network)
Oculus-ASR
from https://twitter.com/planet4589/status/1143518635505475584 changed to follow 44346 in network, however from orbit data that described on the same thread on the linked tweet it could be also 44352. Still no signal, so difficult to say.
We decoded one of the TBEx satellites. We now think BOTH are on 437.485. So, we are looking for both A and B on 437.485. It seems we were in the first group of CubeSats, so objects R S or T.
I’ve scheduled a couple extra observation on 437.485MHz for TBEx-B and also added it into db. Please if you fully confirm that indeed TBEx-B transmits also in 437.485MHz, let us know in order to fix future observations to watch the right frequency.
The red line shows the signal we would get if TLE from 44355 were used. TLE from 44354 would be a straight line but as you can see there is a little curve at the start of the observation that is like the one coming from 44355 TLE.
PS I would like to thank again @cgbsat for helping me build this tool by writing the initial code!
So, I’ve just changed the norad id to 44355 for PSAT-2.
UPDATE for CP9 (LEO) it looks like it is 44360 (changed to follow in network), however this norad id isn’t assigned yet to an object from space-track, which means that could possibly change.
