Hi all, I have set up a SatNOGS station. I think I have everything set up right, but when I run “systemctl status satnogs-client” I get " satnogsclient.scheduler.tasks - ERROR - 401 Client Error: Unauthorized for url: https://network.satnogs.org/api/jobs/ ?ground_station=2919”
I have checked the ID and API Token many times, but I always get this message. It’s running on a raspberri pi3b. Any idea what else could cause this problem?
Thank you very much.
“versions”: {
“satnogs-client”: “1.8.1”,
“gr-satnogs”: “2.3.3.0-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14”,
“satnogs-config”: “0.13.2”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2022-12-21T19:51:21.547087+00:00”,
“distribution”: {
“RELEASE”: “11”,
“CODENAME”: “bullseye”,
“ID”: “Raspbian”
“pending-updates”: true,
“platform”: {
“system”: “Linux”,
“node”: “raspberrypi”,
“release”: “5.15.76-v7+”,
“version”: “#1597 SMP Fri Nov 4 12:13:17 GMT 2022”,
“machine”: “armv7l”
“memory”: {
“total”: 966930432,
“available”: 789254144,
“percent”: 18.4,
“used”: 121487360,
“free”: 591863808,
“active”: 168316928,
“inactive”: 136974336,
“buffers”: 28069888,
“cached”: 225509376,
“shared”: 737280,
“slab”: 35549184
“disk”: {
“total”: 15336914944,
“used”: 4193087488,
“free”: 10465812480,
“percent”: 28.6
“configuration”: {
“satnogs_antenna”: “driver=rtlsdr”,
“satnogs_soapy_rx_device”: “RX”,
“satnogs_station_elev”: “30”,
“satnogs_station_id”: “2919”,
“satnogs_station_lat”: “36.714”,
“satnogs_station_lon”: “-4.252”
