I was wondering what is the current mechanical specifications/capabilities.
In particular
Azimuth rotation speed for 360 degrees with no antenna
Elevation speed for 90 degrees with no antenna.
Minimum step in degrees based on minimum step of stepper motor and gear ratio.
Antenna weight restrictions in KG for typical use.
I know these specifications may change over time but what is currently possible?
