Could I contact directly to owner of ground stations? we want to know specification about other ground station. because other ground station received our CW but we have not received yet. So we want to know what is different.
I think you are a member of the STEP-1 team, so:
I can only tell for myself but I think this would be ok for others, too!
If I can help out somehow, please feel free to contact me. If you have more than “We received your beacon!”, please share any information on that observation. Also feel free to join the SatNOGS IRC chat on freenode, #satnogs. It’s very active and lot of station owners join it, too.
Thank you for attention about our cubesat and issue.
Actually, we set that if the value of voltage of battery is less than 6.8V, the cubesat will switch over emergency mode and then CW signal will not be transmit anymore until battery voltage is recovered to 6.8V or more for itself .
In present, our cubesat have some problem that the battery cannot charge enough as that we expected in advance. Therfore, cube satellites are continuously repeating the transition of the emergency mode.
Your ground station receives our beacon signal more clearly than other ground stations, and the frequency is also high. We don’t know well why your station can receive easily our beacon signal that others.
So we want to transmit telecommand for solving aforementioned problem to the cubesat using your ground station.
If we are available to use your ground station, Could I visit to your station with our some equipments to communicate with our cubesat.
However, we need to confirm in advance whether our equipment is compatible.
Hi
Thank you very much for your active participation in my question. As you know, I am facing the problem of battery voltage as I told Mark. Our ground stations are not able to receive beacon signals clearly, so we want to use ground stations in other areas. We are going to try to listen here because the toxic signals are clearly coming in from Australia. #satnogs
My ground station is receive only, and is only using a turnstile. For a reliable uplink you will need a much bigger antenna system. Unfortunately I cannot provide this.
