I’m writing a script to automate the recording process for my ground station. I want to accomplish the following functions from my script and I am not sure how to do it:
Press the engage button in the GUI to engage GQRX and my SDR
Press the track button to allow the signal to be adjusted for doppler shift
Toggle the record option in GQRX.
Any and all information appreciated, even if it is just a pointer on where to look next. I’m so close to getting my ground station up and running I can taste it. Just need to vault these last few hurdles.
I’m trying to decode telemetry data from the STRaND-1 cubesat. The satellite I’m targeting is using a 9600bps ax.25 FSK modulated packet radio. Which demodulator do I use in GQRX? Is it the CW-L demod?
Thanks.
Lorcan.
EDIT: I can’t find the transponder in the drop down menu of the Gpredict radio control panel.
It depends on what the data decoder requires as input. I think normally they require the audio to be FM demodulated already, so you need to use narrow FM mode and select deviation 5 kHz or maybe more. Make sure the filter is wide enough (20+ kHz ?).
Otherwise USB can be considered as the “raw” demodulator.
Thanks for getting back to me. I’m assuming I will leave everything default until a bit of trial and error can determine if it works? I was under the impression that for such a weak signal I should turn the gain right up on the RTL but perhaps I am mistaken?
I suppose you can call it baseband, though what baseband is depends on the context. For instance, in voice communication the audio would be the baseband
Anyway, I am referring to the IQ recorder, which will record the samples coming from the device without any processing.
