Communities to help Track CubeSats?
We just uploaded a few sample I/Q recordings of a housekeeping packet and a simple “ping command” that amateur operators can send to our public GitHub repo. Hopefully these are able to help!
https://github.com/ASU-cubesat/phxsat-gsw-public/tree/master/Recordings
We have also included supporting documentation in this folder to describe the structure of each recording so you know what you should expect to see.
I should note that the a housekeeping packet recording just includes data from our EM AX100 transceiver, and is not the exact same hk packet that the satellite will usually transmit. We didn’t get the chance to record the spacecraft’s typical health beacon before delivery. We would need our OBC to recreate the satellite’s health beacon, and our only module flew with the spacecraft.
