Bias-T with the HackRF seems not working anymore
Hello,
I am in the process of updating my stations to the latest Docker version.
Station 3543 has a HackRF with a LNA which is powered through the coax cable.
I have this line in my station.env:
SATNOGS_DEV_ARGS=bias_tx=true
It seems that this is not working anymore. The bias_t does not turn on.
I tested the bias-t from the hackrf and the lna manually and that seems to work.
Alternatively, I can power the lna with USB off course, but the bias-t is in this case much easier.
Is this me, or is this a problem with the client?
Thanks for the help!
You can also try:
SATNOGS_SOAPY_RX_DEVICE="driver=hackrf,bias_tx=true"
Thanks Jan, I will try that.
For now I have solved the issue with external power.
I also had this problem for a long time. I now changed to:
and now the Bias-T is finally working again.
Thanks! I will try again.
