Antenna Switching project
Hi Dan, thank for the simplest script formula…
The script seem not reading correctly freq value, I believe.
ve2dsk
Jul 31 15:10:06 raspberrypi satnogs-client[16943]: + gpio -g mode 21 out
Jul 31 15:10:06 raspberrypi satnogs-client[16945]: ++ date ‘+%F %T’
Jul 31 15:10:06 raspberrypi satnogs-client[16943]: + date=‘2023-07-31 15:10:06’
Jul 31 15:10:06 raspberrypi satnogs-client[16943]: + freq=0
Jul 31 15:10:06 raspberrypi satnogs-client[16943]: + getopts f: option
Jul 31 15:10:06 raspberrypi satnogs-client[411]: rig_init: rig does not have rx_range!!
Jul 31 15:10:06 raspberrypi satnogs-client[411]: network_open: hoststr=127.0.0.1, portstr=4532
Jul 31 15:10:09 raspberrypi satnogs-client[16949]: Found Rafael Micro R820T tuner
I’m not sure what you are running there, but it’s not any of the ones I suggested.
Hi…
Ops… bad syntax on my post script, my fault…!
Working well now…
Many many thanks for help and your patience…
VE2DSK
Aug 01 22:51:20 raspberrypi satnogs-client[832]: UHF antenna selected
Aug 01 22:51:20 raspberrypi satnogs-client[402]: rot_init called
Aug 01 22:51:20 raspberrypi satnogs-client[402]: initrots4_gs232a called
Aug 01 23:15:04 raspberrypi satnogs-client[1432]: VHF antenna selected
