502 Bad Gateway - fixed
Heads up,
502 Bad Gateway on https://network.satnogs.org/. Wouldn’t start a topic if it wasn’t Sunday evening :slight_smile: so I figured it’s best to let you know.
Good luck!
Thanks @ivor! There is a misconfiguration on the containers responsible for backups which consumed all disk space on the host. It should be fixed now.
That was quick! Yup, can confirm, I can access the network now. Thank you!
